Interior plastic cleaning recommendations for center console?
Boston, MA
So my new-to-me FJ80 center console has all this discolorated stuff that I can't seem to get off with soapy water or Goo Gone. Actually hard to tell if it's something of the surface, or if's the surface itself getting worn away. Anyone have recommendations for what to clean it with or treat it with? Sorry if it's the wrong forum for it, not sure if this is technical or not :)
full
Mr Clean magic erasers work really well for stains. I cleaned up all the plastic and headliner stains. I think its just hydrogen peroxide on a fine sponge but they are cheap.
Because the surface is not uniform, an abrasive will not work. I would recommend some simple green with a soft bristle brush.
You can get an aerosol made to match the original gray and respray it. It'll look brand new if you match the color from a part that isn't oxidized.
I've also used a heat gun to carefully heat up the plastic where it brings up the original color back to life.
You can damage if you put too much heat. Its all about how close/far you keep it and the movement of the gun. You'll be surprised how well it works.
