Alright, let me first sya the truck was not driven on a regular basis most of last year (just weekends).
First, I have water along the pinch weld on the passengers side. At first I thought it was the often culprit of the sunroof or windshield but I have ruled these both out. I pulled the trim and carpet back and wet vacced the whole area. One of the rubber seals under the sill plate looked like it might be the problem pulled it and replaced. Next day, drive to work and notice the floor is soaked again. Pulled the carpet back and there is more damn water so I pulled the seal and put a bead of silicone around the mating surfaces and replaced then I ran a second bead around the seal and body to seal the interior side.
Drove home, no rain but a lot of standing water and the floor is soaked again. This leads me to believe that this seal is not the actual problem but the water has to be intruding from the underside. Has anyone else dealt with this and if so what was the problem. I do not see any other seals in the area that is getting wet. The water is concentrated to the first inch of carpeting and the pinch weld that is covered by the sill plate. It is enough that it migrates to the second row (same area).
With the weather the way it is here (raining alomost everyday) I need to resolve this fast.
Secondly, I have noticed that my front dome light does not come on consistently. At first the light was not coming on so I figure replace the bulb abd all would be good, replaced the bulb and no joy. Checked the circuit and everything seemed to be good but still no light. Then, a couple days later I disarm the truck and get in a looky there I have light -- works for about two weeks and then back to nothing. It is a simple cicuit and I am really not seeing anywhere where it could be shorting intermittently. I really do not want to pull the headliner down but will if I have to. Has anyone else experienced this and if so how did you resolve the issue?
