Interior Bolt Part Numbers Help
Virginia
In the process of working through my interior - carpet / replacement seatbelts etc... and trying to verify part numbers on hardware. I found this link and think I have it right, but also cannot find some part numbers. Hoping others here might have them or know a place. Thanks!
https://toyota.epc-data.com/land_cruiser/fj62g/61738/body/7151/ Using this as my reference.
For the front seat mountingit appears to be Part Number 90119-10406
I can't find the part numbers for the seat belt to floor bolts, back bench seat mounting bolts and screws for the plastic floor runners on each door. Or the plastic replacement grommets that you screw into for those trim pieces to anchor to. Anyone have these by chance?
AI gave me the following part numbers for those I couldn't find in the above manual. Can anyone confirm??
  • 2 seatbelt part numbers - 90105-A0163 // 90105-A0088.
  • Back Benchseat Floor mounting - 90080-11396
  • Nylon fasteners for the door trim and chrome trim piece in the cargo area holding the carpet down - 90189-06043 // 90189-06043 // 90189-04014 //90189-05013
Ones I can't find anything on is the screws for the trim pieces along the floors of each door and the screws for the plastic covers below the dash on the left and right side.
Thanks for any and all help!
Seat belt bolts are part of the seat belt assembly and are not sold separately. They are an M11x1.25 thread.
Seat mounting bolts are no longer available. They are an M10x1.25 thread.
The rear bench seat mounting bolts, those which hold the hinged front feet, are a standard 91651-60816.
Scuff pad (the trim on the lower door threshold) screws are 93566-54516. The retainers are 90189-05012. For the rear chromed steel trim the screws are 93546-24516. The retainers are the same.
Kick panel screws are 93560-54020.
Try looking a bit more thoroughly in the online parts catalogue, think of a few sections where you might find what you are looking for. For example, the scuff pads are under the floor mat section, the kick panels in the interior trim board.
AFAIK seat belt bolts were standardized to 7/16 UNF like 50 plus years ago.
I think the two are so close it's hard to tell them apart. Certainly, my M11x1.25 tap sits perfectly on a factory seat belt bolt. In the few applications where Toyota specify separate seat belt bolts, they are 90119-110xx which denotes an 11 mm fastener. If it were a UNF bolt, it would be the only bolt in archaic units on the vehicle as far as I recall. The only non-metric fasteners I have come across are tapered threads and some hydraulic/AC connections. They also use non-metric O-rings. But I am of the opinion that the seat belt bolts, at least on non-US vehicles, are M11x1.25.
Yes, but the OP is in Virginia so odds are his bolts are US Spec 7/16 .
I wasn't aware that it was mandatory to use that size of seat belt bolt in the US. I doubt Toyota tapped different threads in the floor pans, so maybe they are all UNF. Or maybe not. I don't think the bolts will ever be long enough for the tiny difference in thread pitch to become apparent.
