Interesting Intercooler
much better than the H3t
I likey
I'd imagine cutting through those hood supports could significantly weaken the hood, possibly making it flimsy. I have been considering a top mount IC like this but I would leave the hood supports in for strength.
Pretty cool truck though. Too bad we can't have diesels here.
Tapage did something similar on his 60, he seems pleased.
From what I gather, running a hood scoop IC will help at freeways speeds, but not at lower speeds, so it all depends on where you want the power/economy to function better
Have you been through much rain as of yet with your intercooler setup? I recall you setup from awhile ago.
My concern with this setup has been in a strong rainstorm you may have issue with water ending up under the 5th and 6th sparkplug boot. Any problems?
It'll never work..... it says for WRX only :D
Do you have inlet and outlet dimensions? outlet appears small but the layout is right.
Layout does look pretty workable. I think that one has a 2.5 inch outlet, so a little small. I did find some with 3 inch outlets but they were big bucks (800ish) I would imagine though that with the power that some WRX's put out they must flow pretty good air.
IIRC the WRX IC you posted has a larger outlet on the underside as well, so it would be difficult to make it work.
Check ebay. They had some IC's that were similar to the one Brett used and they were only $50-60 last fall when I was looking at them. This is still on my to do list. I have the scoop, but I need to gather the rest of the parts.
