First and foremost, I have not done anything in regards to diagnosis or bleeding or anything yet. These are just my symptoms right now. My neighbor who has a lift and a vacuum based bleeder is out of town so I have yet to do this. Once he is back I will bleed the lines and see if that helps, but just wanted to get ya'lls opinion on this just anyone else has seen this.
I am trying to troubleshoot a problem with my brakes. At speed, they seem to work fine or at least it seems so. Comes down in speed in what I would consider normal fashion, however I have not tried to slam slam on them and lock them up. When going 20 or so MPH, it takes a bit more force on the pedal to make it slow down. I know the booster is working as I can feel a significant difference in pedal with the engine off vs on. Now I am thinking two possibilities here...one is that the brakes may have a little air in them, the second is this...I bought this unit with OME 850J in front and 863's all with 30mm spacers in place. I have NO idea if the installer adjusted the LSPV or not.
Once my neighbor gets back and I can use his lift, is there anything else besides these two things that I should be looking at? I am really hoping that someone has ran across this issue already and knows what to go looking for.
