Intake Manifold Coolant heater kit
NorCal
This is a plate that bolts to the bottom of a stock 2f intake manifold, where the exhaust manifold normally bolts up. It has two heater hose fittings that you'd insert into a coolant stream somewhere. It would serve to pre-heat your intake so your engine would warm up faster.
Got it? No pics, sorry. $20 + a ride from 95037. Money back for defects, but not change-of-mind. Comes with a used gasket and 3 long bolts. You use two studs in the manifold for a total of 5 connectors.
