Intake hose
Bend, Oregon
I haven’t been on the forum for a while so don’t know who the go to parts guy is these days.
I am needing the intake hose for my 1994 Land Cruiser. Part # 17881-66060-A.
Please let me know who to contact.
Cheers!
cruiser parts has them and ive found them on amazon but they aren't oem Toyota and more expensive...
Nice! Called and ordered new one for about $110. Local dealership wanted $170. Thanks and if you are ever in Bend, Oregon I’ll buy you a !
The OBD2 type are readily available aftermarket, like this: https://www.amazon.com/XtremeAmazing-Intake-Toyota-Cruiser-1FZ-FE/dp/B01MED6CFH/?tag=ihco-20
Haven't found them for the early motors? With a quick trim the later type can be made to fit.
That’s a lot cheaper but I got 12 years on the this one so getting an OEM for $110 wasn’t too bad. I just forgot to disconnect from the intake before lifting the lid. I’ll keep the duct taped one as a back up. Thanks again!!!
If it was brittle enough to crack doing that, it was time. Would rather have it crack when being serviced than unnoticed, potentially running it while sucking dirt?
Happened while doing an oil change in my garage so very good timing for it to fail. I just need to make sure I disconnect before changing filter!!!
Even here in the desert heat we have seen many of these last 20-25+ years. I would guess that some of these that seem to die MUCH younger may of been mis treated in their young and early days, perhaps by a Toyota mechanic in a hurry to stay at 3x book time, or just an inexperienced back yard wrench jocky that assumed that this old hose would flex like the one on his vacuum cleaner?
This was all me. I am the only one to do anything on the LC. The rest of the hose is in great shape, just split at the ribbing portion when I forced the lid up to swap filters. I take full responsibility for this that is why $110 is a pretty cheap reminder to follow the rules.
