Instrument panel light problem. Any ideas?
Seattle, WA
Hey all I've got an interesting problem. Last week my entire instrument panel went dark. The shift indicators still work fine, turn signal indicators, fuel low light, check engine light, open door, diff lock lights, etc all work fine. Only I can't see the speedometer or tachometer/odometer at all in the dark. So I checked the fuses. All work fine. Poked around on the forums some and found a few posts about replacing those lightbulb so I laboriously removed the dash and popped out the instrument panel and changed the bulbs but strangely that didn't fix the problem. Just wondering what you think might be the issue?
It's a1993
If they all went out at once most likely you lost a ground wire somewhere. The EWD will show you what wires and connections to check.
I know it won't pass the FSM test/repair procedure, but when my gauge cluster goes dark, a good smack of my palm to the top of the dash brings all the lights back ;).
That's my electrical repair method of choice!
What is happening to illumination with the other dash switches? Do you have tail lights? If the lights on switches are not working then my guess the dimmer has failed or become disconnected or the 15A Tail fuse has blown.
The good ol' Chevy Smack! Works all the time most of the time!
Really though, it worked on my driver's side door window for about a year and a half before I replaced the motor...
