- Joined
- Aug 30, 2004
- Threads
- 4
- Messages
- 5
I know that there has been numerous posts on the subject but I need some help on instruments. I have a 1970 FJ-40 with the following issues. My Temp and Oil pressure gauges are not reading correctly. The water temp gauge is all the way to the right and when the vehicle warms up it comes to the cooler side. I got to looking at the instrument cluster and the wiring was jacked from previously so I fixed that, but still the same issue. The Oil pressure gauge stays on the left and doesn't move at all. I know the vehicle ahs pressure though on the oil. I have an aftermarket pressure sending unit in it right now. Is there someone out there that rebuilds clusters? I would like to keep the factory cluster in it, but am looking at putting aftermarket ones in to fix the problem. Another issue is the Speedo just quit working awhile back as well. I can hook a drill up to the cable and it works fine. Is there an electrical lead from the speedo sending unit to something? Thanks for the help in advance.
