Instrument cluster woes
Charlotte, NC
I am in the process of replacing the dashboard on my FJ80 and decided to upgrade the instrument cluster bulbs to LED. After I tested it out, the center PRNDL worked for a second, then stopped working. I put the bulbs back in and it just gives a dim glow. Also, the bottom row of indicators doesn't seem to light up when I switch the key on. Going back to bulbs didnt do any good. Did I let the smoke out? Advice?
There used to be a white indicator light that came on right bottom, above the diff lock lights. No more. ???
Is there a way to test the instrument cluster on the bench?
Is there a way to bench-test the instrument cluster?
I'd check your fuses. Did the gauge fuse pop? I'd take a good look at the connectors to the cluster too. Are you sure you seated them back in snugly? Did you try unplugging them and seating them again, and giving them a bit of a wiggle?
I suspect these could be two separate issues, as the PRND2L lights are not really part of the cluster, they are in a separate module inside the cluster, but you know that already. I would certainly check the fuses, and if you have a circuit diagram of the module, you should certainly be able to bench test it, at least with 12 volts. Check all grounds as well, as not having a voltage return will cause them to not light up.
I have a 97 electrical manual if any of those diagrams would be useful to you?
He can even check most LED's with a simple 9 volt battery if that's more convenient.....for bench testing.
Yep, I checked the gauge fuse and it is ok. Plus, it would affect all the gauges, right? Not just a few? I pulled the connectors out and reseated them several times. No luck.
How do I check the PRND2L lights? I completely backed out all the LEDs and installed the bulbs again. Still doesn't work.
Also, none of the warning lights (oil, etc) work. Could this be ECU related?
So you reinstalled the incandescent bulbs and it still doesnt work? If so, then I would pull the whole cluster out and start bench testing it and like others have said check for bad grounds.
Also, you know that a lot of LEDs are polarity sensitive and if they dont work one way flip them 180 and retest.
Yep. Some are some are not. 👍
I always 'test' any LED that I am going to install with a 9volt battery and some leads. It's not enough to check them for continuity with a multi-meter. LED's can burn out the second you apply power, flicker, etc.... You just don't know until you put power to them. Good quality LED's will work and last a long time though.
Some diagrams from a 97 Land Cruiser if they might be useful for troubleshooting.
Additional Combination Meter diagrams
