Okay, so I've been searching high and low for possible options here, and I know that this has been discussed extensively, but because there are so many options, and I've never dealt with a 24V system before, I'm getting a little confused as to how I'm going to set up.
Please bare with me as this may get a little long winded:
I'm leaning towards a Solar Converter setup with a 24V relay to switch "off" the load balance mode when the ignition is turned off.
The PO installed a 10amp 24v-12v down-step converter near the center console for running 12V accessories inside. This seems to work well, and at first I was considering running the new head unit off this, with the constant for the stereo's presets tapped from the low side (12v) battery. Then the Solar Converter would be able to balance out the batteries when running.
After reading probably every post there is on the subject, I'm now thinking of getting rid of the old converter all together and using the Solar Converter to do both jobs:
1. Providing the 12V for accessories + stereo + possibly an alarm and 2. balancing the charge of the batteries.
My question is, if I do the second option, how would I set it up so the ignition closes the relay circuit?
I would also like to have the accessories (3-way cigarette lighter plug) on even with the ignition off.
Am I asking too much from my poor batteries with this?
