Installing CCOT Wheel well supports
Paint Lick, KY
Website
www.globalsoftware-inc.com
I am installing the Real Steel wheel well tops this weekend and also the CCOT wheel well supports. I'm about to weld in the supports and could use some opinions about about where they 'should' be. I will be re-installing the MAF rear roll bar which has a 23 11/16 long base. I was thinking that the supports should be centered under the area where the down tubes are welded to the base?
All thoughts would be appreciated.
I like the idea on mounting them centered under the area where the down tubes are welded to the base on the roll bar.......Why did you not use Real Steel supports?
I sure wouldn't put the supports in before completing the inner fender install, you're gonna have nine kinds of hell with fitting. Just my opinion...and experience. I put all mine in the factory location.
Wow, I see your point. While just test fitting it I had to 'tweak it' to get it to align. Withtthose ultra stiff supports welded in I would not be able to do that. Thanks for that tip, exact reason I posted this!
The wife pulled me off the Cruiser for some fall clean up before I got that far. Just got back down here in the garage. I will weld the fenders in first then attach the supports. Geez that means overhead welding... I hate overhead welding.... I'm not any good at it :-)
My 2/71 never had supports from the factory, it's the reason I'm adding them. They will hold the rear cage until I can get the full cage installed.
