Dear ,It is/was cheaper to have a single wiring harness with all optioned connections to have multiples with only specific options.
For example, if your rig does NOT have lockers you have the same wiring harness as a rig WITH lockers.
Dear ,
Shouldn't the knuckles have a place to put the abs sensor even if it is not built with abs ?
Good question... Wire and connectors are cheaper than machining?Is it a yes to my question ? Or you don't know !?Good question... Wire and connectors are cheaper than machining?
