Inner axle seal
Staunton, VA
Was repacking wheel bearings in preparation for a little road trip, about 500 miles, and noticed a leaking inner axle seal. I leave in three days. I live in Virginia so no land cruiser shops near by and Beno is on vacation until tomorrow.
Couple questions:
Do you have to remove the knuckle housing to replace the inner axle seal? I've done a couple rebuilds on 60s and 40s but I can't remember. Maybe the 80 is different?
Is it worth popping a "autozone" or similar seal in there for the time being? I plan on a full rebuild in the coming months.
Should I just repack the bearings, squirt a bunch grease in the knuckle and hit the road?
Aaanndd does anyone have a seal on the east coast the would want to overnight me?
Whats the oil level like? I'd say check it, throw in the 5 dollar one for the moment if its already torn down, get factory when you return home. If you do, make sure the shaft isn't marred or grooved, or that seal isn't gonna do jack, if ya didn't know
Any Toyota dealer should be able to get the seals overnight but you'd want to call them first thing tomorrow. However, I vote for adding grease and rolling. Maybe stick your grease gun, quart of gear oil and your 24mm in your truck before you head out.
I just changed the gear oil in the axle.
The "leak" could be described as the wetness on the outside of the knuckle but no dripping onto the tire yet.
Jon, I am familiar with Iron Pig, but I didn't realize Vince had gone off on his own. I'll try those fellas.
Seems like the overall feeling is top everything off and run it. I think that's probably what I will end up doing.
Another question,
When I removed the dustcap that covers the outtermost C-clip that keeps the birfield from slipping into the front differential the c-clip just fell out. Apparently, someone before me did a less than stellar job putting things back together. Would missing that C-clip cause enough in/out movement of the axle shaft assembly to allow leakage past the inner axle seal?
Retail parts sales are better left to guys like Beno, but I do have couple of OEM Toyota axle seals on the shelf and would be happy to bail out a fellow Cruiserhead. If you decide to crack into the knuckle before your trip, give me a call so I can get it in the mail ASAP. Nathan w/ Forge Specialties 540 693 4603
Hey Nathan, THANK YOU for the offer, however I decided I'm not going in that deep.
Turns out you have to take the knuckle housing off to get to the inner seal. I said piss on it. Packed her full of grease, repacked the bearings, and buttoned it up.
Any idea what would cause damage like this? Bad picture, but those are very large grooves on the shaft of the birfield. The spindle and the bronze bushing looked unscathed, but the grease (soup) that was in the knuckle was filled with little flecks of gold. Maybe a previous breakage with a sub standard repair?
The area where the bushing rides doesn't look bad, if the bushing is good run it. The rest of the birf shaft looks normal, it's not critical, doesn't touch anything, so is casually machined.
Wow! I guess if I was THAT close on it, I would have put in the aftermarket seal and called it good, even with the offer from Forge Specialties! You were within 30 seconds of accessing the seal, another 5 minutes to pull it, 15 minutes to install a new one, and away you go!
Oh, well.....I wasn't doing it and you're happy with your result. Good Luck!
Pull your wheel speed sensor out and pull your axle. You don't need to pull the trunion, I just did it.
Well s***.... I tugged on the axle and figured there was no way I could sneak it out of there without pulling the knuckle housing. I guess I'll know next time.
The autoparts store ordered the wrong seal and didn't have the right one anywhere close. I could have used the one from Forge Specialties, but it's all back together now.
It's getting a complete rebuild in the future. I'm hoping with the lock-ring in place on the end of the Birfield like it should be the leak will be slower.
Thanks for the help guys!!
Correct on the above. You don't need to pull the knuckle housing to do the seal, but you do have to pull the AbS sensor to get the birf out.
One thing to do, if you haven't already, is check your diff breather on the frame. They clog fairly easy and cause the front axle to over pressurize which pushes the oil into the knuckle. Just a simple thing to check and verify. Usually blowing through it with compressed air will clean it out.
Good point. I'll check that out.
