Injectoritis
Sandy Utah area
So...I had an injector crap the bed (283,000 miles and counting) and im looking at a couple of options.
1. replace them all
2. replace one
The trouble with option 1 is that Toyota only has like 5...in the country...so thats kinda out.
Im looking at either one new Denso (toyota) or replacing all 6 with remans (or 3rd party)
Anyone have suggestions on good brands? Anything to stay away from? any other options?
Just for curiosity, which injector failed? 1, 2... or 6 ?
I personally would replace just the dead one. Then get a rockauto reman using your dead one as an exchange. Keep that one as a spare.
I'd send the 5 in for cleaning/testing etc. Buy new seals (head facing and fuel rail facing) and replace all of them. I'd go toyota for the seals.
Cleaning places replace the seals but I kept those as spares and put in new toyota ones - not wanting any leaks etc.
cheers,
george.
cheers,
george.
RC auto cleaned and rebuilt all 6 about 30,000 miles ago, I neglected to mention. #2
I'd replace the dead one with a new one. The failed one (#6) I had went open circuit as its failure mode. Get a reman with your dead one as a core from rockauto (pretty cheap).
I personally wouldn't spend the $$$ on 6 new ones. Injectors should last a long time (till they fail...).
I presume you've verified its an actual injector failure versus a wiring/connector issue.
cheers,
george.
cheers,
george.
Its in the shop, but its a shop I trust. They tested the wiring and it was getting a signal iand then they hooked it up directly and got no response.
You think even at nearly 300,000 miles the current set still has life left in them?
Well, claimed web life of an injector is 1 billion cycles minimum. So, assuming 2000 rpm (1000 injection cycles per injector per minute, that's over 16600 hours to get to 1 billion pulses) and 60mph average means 1 million miles minimum. At 2000rpm average over life and 30mph average over life you're at 500k miles.
Obviously they do fail earlier than that... fuel quality, heat, vibration, bad luck...
So, up to you and whether you have an xmas bonus coming :)
cheers,
george.
