Sheesh, not even I can save you from yourself!
I didn't claim a "performance difference" in terms of the HP or torque or anything but it simply stands to reason that with the injectors balanced and all running 308+ versus a range of say "288 to 302", "performance" will increase in the sense of much more similar combustion chamber energies, much more similar emissions chamber to chamber and a much better reading and response from the O2 sensors as a result. I don't think there's a "2+2" out there that can argue against that but whip out the fuzzy math foolishness if you want. In any event also not "recommending" this as another PM on its own; in my case we had the injectors out for the HG PM (pulease don't try to math out the value of that either) and it was a "might as well" thing that I decided to do and also based basically on Robbie's recommendation. Lastly, my experience essentially proves that the performance of the injectors does degrade even with extra maintenance by way of BG 44K and BG fuel rail flush which I thought was what you arguing about in the other thread? Anyhoo, with or without your permission
or recommendation I will do what I want and I'm glad I did, thanks.
I could care less *if* you do it. I don't agree it's PM, I don't agree you can measure a difference, and I don't believe it should be a recommended procedure. I claim the cylinder variance on a 100k (even a freshly rebuilt) motor is beyond injector balancing by a significant factor. Do a compression ck, or a leak down test, what's the variance between cylinders? The FSM lists 8% variance between cylinder pressures on the highest/new motor compression spec (171psi and 14psi variance=8%). FSM on Fuel Injector flow is avg296cc x 8% = 264cc, which just happens to be the 'low' fuel injector spec variance. So what good is a 'balanced' injector, as long as it's within factory spec?
The difference between what I read here, and guys that deal with CIS and EFI all the time for a living, is just 'n'. The stock injectors on the 80 are overkill. The stock Bosch production tolerance would be excellent at 2% differences. The stock FSM diagnostic for fuel injectors is well documented. Servicing them in any fashion, lacks documentation for good reason. The logic should be to just get new injectors, cuz cleaning only gets you to mid spec. So new should get you the 'best' spec?
I know what this procedure does, and it's potential benefits. 25 years of turbo cars running 3-4 times the boost level of any truck here, never did a batch injector clean as PM. Never had to. Have I diagnosed bad injectors? Sure. Have I replaced screens and cleaned out injectors with compressed air and some solvent? Sure. Would I ever recommend taking 6 good injectors and dumping 200bucks having them cleaned and balanced (there is no such thing in reality). Never. At most, use the FSM, diagnose which are bad, and send those off if Mr. Injector parts install are intimidating.
I just don't find injectors mysterious or require expertise to diagnose and service properly. The argument starts because folks want to justify the expense. I say you can't unless you did the FSM test, and then it's per injector service, not the lot.
The hardest part of injector service is the R&R of the injector. I claim if you can do that correctly on your own without blowing up the truck, you can spend 20bucks with Mr. Injector, and save 10 times the money you spent. Again, I'd love to hear C-dan's comments via his master techs.
YOMV
Scott J
'94 FZJ80 Supercharged
