Info Tag Question!!!
Snowflake, AZ
Website
www.metal-mayhemaz.com
Hi! Quick question. We are in the process of restoring a 40 series Land Cruiser. We have the VIN tag and the body tag, however, we know there is one that needs to be around the glove box. Can someone assist in letting us know where we can find one, and a specific spot on where it should be located? Thanks! :)
It was actually for the one that goes on the glove box, like an information plate. We're restoring a 1969, and that's the plate that we never had. I went on SOR.com to find one, and only found one for a 1971 and newer model. Hoping it will fit and work just the same.
@Troy Rogers :
I believe you are referring to a shifting information plate, such as this for the three speed transmission and transfer case lever on the floor:
If your FJ40 has a different transmission, or vacuum shift and pull button, you'd need something different.
P.S.: My wife's 1977 Chevy Monte Carlo odometer turned to 33,333.3 miles in the Fall of 1979 in front of the Sears store on the main street in Snowflake. We were on a drive from Holbrook to Phoenix.
what year ?early 40s had the vin on the right front fender
The pre factory FJ40 the VIN plaque was on the firewall.
my 69 has the one in the photo
That is not the one for the US market in 69. Those still had vacuum shift with lever on the dash. If converted to transfer case floor shift this would be right if still has a three speed.
