Increased idle issue
Sacramento, CA
I have an F145 engine with a Weber carb. I've noticed that when I pull up to a stop sign/light, push in the clutch, the engine starts to rev. I tap the throttle to give it a little gas, and it returns to a normal idle. It's super annoying.
I checked the linkage, and it seems smooth. If not the linkage, what could it be?
Stronger return spring might fix it. Perhaps bushing in linkages and the carb are corroded, spray everything with carb cleaner. Then put some good oil on them - sewing machine resists gumming up.
Oddly I do not have a return spring?
Well there you go! I used to run a Weber and although the throttle plate springs are quite strong I had to run a return spring or it would ( always/sometimes?) not fully close. I suppose you could spray carb cleaner and lube etc. if it formally fully closed on it’s own and might find success.
Did you ever add a return spring?
