Okay i have an 86 toyota pickup, it has 32's and of course the speedo does not read the right speed because of the wheels. What can i do to correct the speedo being off?
Even better, auto or manual transmission? (No I'm not stupid, I realize you most likely have the 4 or 5 speed, but this'll help for searches later.)
*From what I have seen..things are always a little different sometimes, but this should all be correct for up to 1995 vehicles.
There's different gear outputs for the manual that you can swap in and avoid the whole speedo correction gearbox nonsense.
IIRC you probably have a 17-18 tooth and want a 19.
The bolt that holds the speedo output is on top of a small plate and is a 10mm. Unbolt it, look at the plastic gear to get your count, then step it up however many teeth to correct things.
IE: My R150 came with the newer output and 31 teeth for 28" tires. I wanted to run 31's.
31"/28"=1.1071429
1.1071429x31t=34.32143..33t being the closest I had available.
So, let's say you have gone similarly, from 28's to 31's and have a 18t output..
31"/28"=1.1071429
1.1071429x17t=18.821429.. go with the 19t since it'll put you closer than a 18t would.
Make sense?
If it's an auto, you can do similar, but only if it's a 4wd version, as the 2wd's tailshaft assembly uses a different style output that is not interchangeable.
(4wd=Transfer case, all the transfer cases use the same output as the manuals do.)
