So I bought a Uniden 520 fully planning on installing it in the ashtray location. After tearing apart the dash to begin the install I decided I didn't want to hack up any of the trim. Instead, after looking at all my options I decided to use the bracket that came with the unit, modify it so I could remove it, and install it in the center console. I then removed the speaker from inside the case, ran the wires out the external speaker hole and mounted the speaker on the side of the center console. I used the top of the case as a guider for marking and drilling the holes in the center console. The antenna cable runs along the PS under the trim and I drilled a hole in the PS compartment in the back to store the mag mount base when I'm not using it. The plan is to put it either on the roof or fab a bracket to mount to my bumper carrier. I'm very happy with the install over all.
-Patrick
-Patrick
). I don't plan to run it unless on trips or wheeling. I wouldn't expect any heat issues. Certainly no more than right above/beneath the radio or in the ash tray slot. There's not a lot to the CB circuit board. The speaker probably took up 2/3 the volume inside the chassis. I also don't load up the center console with a lot of junk so I think it will have plenty of air to keep cool.
