In cab vacuum gauge...
Buffalo, Wyoming
Ok, rocket scientists.
The bottom line is: Figure out the valve adjustments for a cold engine and post here. :D
Seriously, who makes an accurate dash vacuum guage?
I have used Autometer guages before but no vacuum. Figured I'd ask from people with experience.
Thanks for a confimation.
I am beginning to not like this forum. Every time I get on here I see new things to spend money on. I am gonna have a $30,000 Fj40 by the time I get done:frown: Better than a drug addiction, I guess.
Installed an Autometer gauge back in 2000....works great.
I am beginning to not like this forum. Every time I get on here I see new things to spend money on. I am gonna have a $30,000 Fj40 by the time I get done..
Only 30K?
You are getting by cheap. ;)
:beer:
Kind of hard to see but the PO cut a radio hole that I filled with a real temp gauge and vacuum gauge - both VDO
... or as my neighbor calls it an "anti-turbo" gauge.
I use Stewart Warner vacuum gages. I'm going to dump my Auto Meter and Auto Gage for SW at my first budget opportunity. I mentioned on another thread that I have in-cab vacuum gages, as well as one in my tolbox to hook up under the hood. My old race car had one installed under the hood for imediate use. A vacuum gage is a very useful tool for diagnosing engine problems, as well as tuning and maximum fuel economy during cruise.
Useful links:
http://www.earlycuda.org/tech/vacuum2.htm
http://www.classictruckshop.com/clubs/earlyburbs/projects/vac/uum.htm
Yes, I have commited myself to this mod as well. I'm thinking of going with VDO as I've used them so many times in the past for VW's. They tend to be small, compact, simple to wire and used to all be made in Germany which means they work well and are made well. They are probably made in Mexico or China by now though.
I would like to cover up the crappy cutting the PO made in the original radio slot, like above I've got a few scars to hide... Temp, vaccum, what else would be a good addition? maybe an accurate oil pressure gauge huh?
I have been running vacuum guages in all my rigs since 1983, and have tried several.
The original Stewart Warner that was in my Merc Cougar was the shizzle, but the one in my K5 crapped out after about 5 years. By then SW had been sold, and their QC went down the drain. Never could trust them again.
Tried VDO; underimpressed.
I've been selling and installing Sunpro guages for 6 or 7 years now. Some last, some don't. But they're accurate AND economical. When one dies, I don't feel nearly as bad.
I'm on my second one in the 45lwb since '94.
Hth
Mark A.
I used a stainless liquid filled gauge from McMaster that had a threaded nipple coming out of the back face. I slightly enlarged an extra stock dash hole and threaded it in. Very tight and the rear connection is a simple compression fitting. I also have a psi gauge sitting next the vacuum gauge and it looks slick.
I would have added oil pressure if there was room
BRIAN IN OREGON,
Are those vacuum charts engine specific, ie. Chevy 350 vs. Toyota 2F?
The vacuum charts are for all conventional OEM motors. Shouldn't matter if it's a 350 or a 2F.
Some readings would not be applicable to some engines, like rotary (Mazda), diesel (especially 2-stroke), turbo/supercharging, and race engines with wild cams.
One thing about these charts is that you can't interpret them as being dead on unless you check obvious things first. As an example, notice the reading that says "poor rings". It shows a lightly fluttering needle that's a couple of inches or so below a normally idling engine. A couple of other things can cause this. Like a big cam, or the carb and distributer are not set right. For the latter, you'd want to carefully tune the engine before coming to the conclusion that the rings are shot. And, if you suspect shot rings, you do a compression test, then squirt motor oil into the cylinder to test it again. The oil should momentarily seal the rings and give a reading closer to normal.
