Improving Snow Capability?
Scotland
I live at the end of a fairly minor road that is quite exposed in places. Although its ploughed twice a day, it still gets drifted in when the wind gets up. Dry powder's no real problem but when its wet it can be a pain.
Current HDJ80 is stock apart from 295 BFG ATs and full lockers and does pretty well. But as always, looking to improve. ;p
Main problem seems to be lack of clearance. Snow builds up under the frame and quickly brings things to a halt. Don't really want to go any bigger with the tyres, but will a lift make any difference?
Any other ideas appreciated :)
Jamie
A lift won't help that much as it is the axle that really builds it up. Only way to get around that is bigger tires, or switching to portal axles.
You could also go with wider tires to help you float more over the snow instead of cutting down into it. Tire width has a significant impact on how much you sink into the snow. You can also air down to increase your contact area.
What about chains? Not the wimpy cable type ones, but really beefy proper chains.
If snow builds up under the frame, then lifting the frame seems a rather obvious solution.
80's (dual locked) go and go until you get enough frame weight on whatever it is you are trying to get over or through, and then what is often a weight advantage becomes a huge liability.
You need more clearance if this issue really matters, there is no way around it.
I vote...
1. sheet metal belly pan
2. suspension lift
3. tire size up
4. portal axles
5. ... (how much more money have you got?)
How many times/year is this a problem? For 6 months? 6 times/year?
I'd say the solution should be commensurate with the problem.
Huge problem = huge solution (see above)
g'luck, Dan.
I've had to dig it out 3 times this year already. So enough of a problem to justify some spending but probably not to the extent of portal axles! :lol:
Thought about chains, but the only ones available over here for tyres as big as the 295's are not far off $1k for a set! :eek:
Will the chains make much of a difference? Always thought they were more for traction issues on hills etc then just ploughing through deep stuff.
Got a mild lift planned later this year. So might just leave it till then see about some bigger tyres.
Other solution, might be to get that tractor and big plow i keep thinking about.
sounds like you need to mount a cheap-blade/plow and run it about 10" off the ground- that way theres no issues with slowing down your rig and it will cut the snow height down to under axle height.
X2 on chains! But it's a pain to have to mount just for your driveway! Do you know anybody that has a plowing service?
Go big or go home.
I re-read and re-remembered you said it gets plowed twice a day
Did I read that right $1,000 for a set of chains!!!
Snow blade looks interesting :hhmm:
Its actually a public road, just one that only leads to about 6 houses and is about 10 miles long in total. But there's only a few exposed stretches that cause problems on a regular basis.
Chains for normal cars and suv's are cheap and easy to get hold off, as are common Land Rover sizes, but the only ones I can find to fit 295's are commercial type chains made by a company called RUD.
How much would I expect to pay over there? Might be worth paying the shipping :)
RUD is a top of the line German brand, generally used on commercial trucks and off road equipment, popular on Unimogs in winter service in Germany. Comparing them to the chains you find cheap for cars is like comparing a TLC to a Yugo, both are technically automobiles, but the similarities end there.
My chains to fit 315's were about $75 per set IIRC. I'm planning on buying the quick connect ones eventually though.
I can see why they charge a $1000 for them, some pretty nice designs. the Roto-grip sytem is cool too.
