Improved handling - FJ60
Hey all. I just found this thread and did not/was not able see the picture that was posted. Any chance of reposting or e-mailing me the actual pic?
Thanks !!!
Landpimp said:
FYI, only 84+ fj60's have the sway bar mounts on axle and holes in frame. If you have a lift get/or make longer sway bar links.
Damn! I was set to do this for my '83, too. Guess it was better to find out now. Is the retrofit a pain?
Cruiserparts.net has the swaybars for about $100.00.
Ask for one thats not too rusted! I went to change the bushings and everything was frozen solid.
Toad
Holy back from the dead! ;p
Do you think that a front SB is all you need? Seems to me it would be.
Any suggestions where to buy a bar?
Stock comes to mind..
Everybody thinks they're funny. When they're not. What if youre truck didnt have one? :eek:
You go get a stock one then...
Simple really..
Look at it this way. I could give you a bunch of different sway bar applications that you would then have to modify to fit your rig, or you could get a stock one that is perfectly prebent and attach it to your front axle with 2 simple mounts.
Which would you prefer?
Well, since my rig is like ten feet tall, Im going to have to modify one anyway.... Thanks.:grinpimp:
You are not listening. You do not modify the sway bar. You just get longer rods to connect the sway bar to the frame. And those are sold by a couple of vendors.. All you have to do is get (or fab) some tabs to attatch the sway bar to your current axle.
It is a lot easier to make the stock bar work than modify another bar to function with your truck.
I agree with Mace here. Took me about 20 minutes of grinding/welding to get to perfection. I wouldnt worry about the added height working as a fulcrum either as the stock was built stout for its application as it is. Just lengthen the rods and voila!
I'm new to this site. I've been a member of the FJ62 site for quite awhile. I have a 88FJ62 with 306000miles on it and it's still running strong. Thanks to what I've learned from that group. I have a 2003 5.3 Vortec including automatic waiting.
Bill in Olympia, WA
When I bought mine, the front swaybar was disconnected. This, and all the play in the bushings, steering ect. made the HJ60 feel like a landblimp! OME, polys, and new steering components made it a new car!!! But I would love one in the back... although never seen one here?
