My truck has developed an interesting new issue: when it's below freezing, I get a crank no start every time. Conveniently I've only experienced this when out in the bush camping, as it has been above freezing in town for a couple of months.
When I wake up in the morning and go to start the truck, it will crank forever but not turnover. After repeated tries however, it finally cranks strong. Checked the battery, and charge is healthy, so I began to think this is a fuel pressure issue. However, the last time this happened I discovered that the key safety light (immobilizer) did not turn off when the key was inserted in these temperatures. Also, when it does crank, if I turn it off and try again, the key safety light turns off when the key is inserted and the truck starts
Do I need to go for the full immobilizer fix with this or does anybody have any ideas for easier fixes?
Edit to add that when key is inserted in freezing conditions and turned to ACC - all electronics light up and function normally.
