Immobilizer issue?
Purcellville, va
I can’t seem to get my 2001 to start. Turns over fine, plenty of battery, no sign of firing.
I noticed when I stick the key in the ignition , the security Immobilizer light above the AC controls does not turn off (I’m fairly certain it used to).
I have no original keys, but 2 replicas, neither work (and same behavior with the light). I’ve been using these same keys with no issue the last 3 years. I replaced the battery in one with no luck, granted I read elsewhere it’s RF based and has nothing to do with the battery.
I’m tempted to try a new key and freshly program it, but that feels premature (so far).
Any ideas or tips? Am I barking up the wrong tree?
Thanks!
If the security light does not go out, good chance it is a melted EFI fuse issue....that can be solved if the case. Look inside fuse box in engine bay. Find the yellow 20 amp EFI fuse. Look at it and the slot it is in for signs of burning or melting.
@medtro has a solution for this common issue.
A thread by @medtro that discusses his workaround:
Th
Thanks for the tips, though not sure where to go from here....
I checked the 20 amp fuse this morning, it looks fine. I decided to give it one more try after popping in the fuse and sure enough, the LC fired right up. So I am at a total loss as to what is going on. For what its worth, that 20 amp fuse seemed seated properly (I recalled needing to give s decent tug to get it out).
On one hand I'm relieved that its back, but part of me is now paranoid it might happen at a less than ideal location or time. Let sleeping dogs lie or dig deeper is the question atm.
