I'm calling BS unless you convince me otherwise
NE Indiana
See pic 1 of the Warn warning on their Fairlead install. I'm using the bottom hole unless I hear a good reason. Pic 2 is its new home. Using the top just doesn't work.
Thoughts?
I'm distracted by the pretty white rope.
Is that some Walmart clothesline?[/
Nope, Rural King.
It's steel, must be the reflection.
Bolt it up
Thanks JZ
Not sure why they even put those holes there if they don't want you to use them. I could find out if I chose to read the instructions, that ain't happnin
You can use them if you want to kill nuns and bus's full of retarded kids.
You can put it in the wrong hole, but you have to clean it up before returning to the correct hole.
So I'm told.
If it wasn't to be used it wouldn't be there, use it as you feel the need.
