Can any body that has done IH Scout psteering conversion on their rig give me some help? Like how does it work? Where can I find a box,preferebly rebuilt (around Charlotte,NC) ? I have read the thread and I have more questions.
The return line pressure on the scout box is extremely strong and will cause flexing of the frame if not reinforced.
Thanx for info fellas. Couple more questions though. At NAPA they listed 4 different ps boxes, as follows:
1971-74 with 13/16ths input shaft = in-stock item
75 ONLY XLC ?
1976-79 3/4" input shaft =special order
1976-79 13/16ths input =Special order
Which one should I get ? I am going to probably get the in stock one if nobody knows.
2nd Question , How different is the steering on a 55 than a 40 ? It seem most of the conversions are on a 55.
3rd question, how much radiator brace trimming will be involved with the placement of this ps box, if any ?
I used the box out of a '77 Scout ( 13/16'sx36 ), Ford tower cut off to match pass/side, bearing for colume , along with ujoint/yokes from Kurt at Cruiser Outfitters, made my own draglink using Toy/Jeep sections cut to length, then sleeved. Grab a steering shaft out of a Toy mini/FourRunner, will be a tad longer than you need, but is made to coliapse in an accident. Mark on the side of the frame where the stock draglink rod end sits, and set your box in place where it's simular, this will keep everything in stock like placement= no bump steer. HTH, Al
