ignition work
HI
Sorry to bother you all again, but I'm at my wit's end tyring to figure out why my truck won't turn over. I've searched through a ton of old threads and got some good info. but nothing that has helped me fix my problem. Now, the problem is that my starter won't turn over. I don't even get a click when I turn the key anymore. About a week ago, after fixing the fuel system, I tried starting my truck and it turned over but would not start. Next day, tried again but got nothing. Starter was just not engaging. I took it to NAPA and they tested it. Tried a new battery and that hasn't helped. Got new battery cables and still nothing. Took out the ignition switch and filed down the contacts, they were pretty dirty. Yesterday, I got a couple of clicks after filing down the contacts, but now I'm not getting anything at all. The only thing that I can think of is some faulty wiring somewhere. Are there any other options besides the faulty wiring? I can't figure out why the truck would be turning over one day and not doing anything the next days.
About my truck: 1972 FJ40, new carb from SOR, new fuel filter, gas tank, fuel lines, battery cables, battery. Please throw out any ideas that you may have. I've tried to jump the starter with jumper cables to the solenoid, but that hasn't helped. Have not tried the screwdriver across solenoid terminals trick. I think I can picture it in my head, but not sure of the details or what it is supposed to do. When key is turned, amp guage drops down. Thanks and sorry for the long post.
Big snip
So what was the result of the starter test? I suppose it tested ok which is why they sold you a new battery. Did you test the old battery voltage or even the new one?
What is the voltage reading on your batteries? Old and new one.
When you apply 12v+ directly to the solenoid switch does it trigger the starter or just click?
Before you perform this test make sure the tranny is in neutral.
I had the same problem. My short was at the volt meter. The volt meter serves as a bridge from the ignition switch and the main feed to the starter. I took a small bolt and bolted the two leads together and she fired right up. Its still running that way, I'm sourcing a new volt gauge seems like its harder to find than I thought from Spector and CCOT. Get your test light and volt meter out and start at the starter. Do you have voltage when the key is on to the starter solonoid? If yes thats not your problem. If not start at the ignition switch. check if your good to the meter and then check the other side of the volt meter to the starter. Good luck and let us know your findings. :popcorn:
Here is the starter test drill:
1) Jump across the two large lugs at the solenoid with a screw driver (1 from the battery cable, other to the motor). If the starter motor runs runs, then the motor is good. If not the motor is bad or there is a bad ground strap.
2) Hot wire the solenoid pull in coil (black wire with white stripe from the ignition key "start" switch pole) by jumping between the battery cable lug and the spade lug on the solenoid. If the motor runs, then the solenoid and starter motor are OK.
3) If not, check for 12V on the black wire/white stripe when the key is held in the start position. If no voltage, key or wire is bad.
Huh?
Stock cruisers don't have a volt meter; they have an amp meter.
The amp meter is in the main chassis feed wire between the battery and the rest of the truck. If the amp meter is burned out there will be no power to the truck.
Big snip
Batteries, both old and new, read 12V with my voltmeter. Starter tests fine at NAPA. Not sure what you meant with the last question. Do mean with jumper cables bypassing the battery cable?
yes:beer: you will find when you do this it will start more than likely,if it does not then look at your voltmeter just for the hell of it.then if none of this works we have more ideas:D
1) Jumped across the two large lugs with a screwdriver and starter motor did not run. Just got sparks coming from bottom lug.
2) I probably did that wrong, but I jumped between them with a screwdriver and had the same result as the first test. Just sparks.
3) Used my voltmeter to test the black/white wire and got between 11/12 volts.
Here's a pic of my starter and I'll try to explain how I tested. Let me know if I did it right. BTW please ignore the dirtiness/rust. That's how I bought it and I haven't had time to clean. Put screwdriver between 1 and 2 (1 is lug on solenoid and 2 is lug on starter) and got sparks. Put screwdriver between 1 and 3 (black/white wire and lug on solenoid) and got sparks. Should there be any wires coming off of 4? It looks like a possibility, but I think it's just the bolt to hold the solenoid onto body.
feel like an idiot
Ok think I found my problem. The ground wire from the solenoid to the frame was unhooked. God, I feel like an idiot. I've been staring into that engine compartment for hours and never noticed it. :mad: However, now I have a new problem. I tried to connect the positive terminal and got a big spark that created a small divot in my battery terminal. Isn't the negative supposed to go on second? I've got myself confused. I think it's the negative second and am going to try that. I feel like an idiot. Can't even remember which terminal goes on in the proper order.
Dammit now that I've connected the ground cable to the solenoid, I can't connect my battery cables to the terminals. I tried the positive cable first and the negative second and I got such a big spark that it partially melted my battery terminal. Can anyone tell me why this is? Perhaps the ground is supposed to go to the bolts that hold the starter to the body and not to the solenoid?
Huh?
Thats exactly what I meant. Amp meter sorry my wording was off. Glad to hear you found your problem.
Cheehoo! Got the starter turning. Fixed the ground wire and then I had to rap on the starter with a hammer to get it spinning. However, it seems like it isn't engaging the flywheel. All that I hear is the starter turning. The engine isn't cranking. When you install the starter do you have to line up the starter gear with the flywheel teeth? I kind of just put the starter back on when I re-installed it. BTW thanks for all the help with this! I've been trying to get it back to turning over all week. I realy appreciate all the help.
https://forum.ih8mud.com/showthread.php?t=76860
did you see this one?
I can't remember what finally fixed it, though, I think new grounds and maybe a new battery.
I think that the reason for the whirring is that it isn't getting enough burst o' power to make the bendix do its thing
hate to say it, but is it possible that you fried your new battery?, do you have another around you could throw in?
The other thing in that thread is the potential for moisture doing weird things, might try heating it up with a torch, and see if it helps.
Also when you replaced the cables, did you sand things up a bit to make sure that you had bright and shiny contacts on the frame, starter, solenoid contacts, battery leads, trigger wire, and everywhere else. (a dremel with a small wire brush works great if you have one)
I used a wire brush on most of the places. Used sand paper on the battery/ground cables so that they were nice and shiny. I think I will sand more on he frame and igntion switch wire hook up for the solenoid. They could use some more. Thanks for all the help people. So far, it seems like it won't turn over, unless I tap the starter with a hammer as I turn the key. I'm going to take the starter out tomorrow to inspect it. Until then, I'll be searching all the old threads again. Again thanks for all the help. :cheers:
If you continually have to tap it with a hammer your solenoid is likely on the way out. If your bendix is not engaging all the way you may have low voltage (have you charged the battery at all through all of these starting attempts?
