Ignition upgrade options
Silicon Valley
Hi,
What does it take to upgrade a '75 ignition system to +'79 ignition? Any other options?
I've been pretty happy with my MSD Offroad igntion/Pertronix setup but the MSD box died 2 weeks ago (after 4 years of service), since the box is potted, it cannot be repaired and the cost for a new one is $250, I am looking for other reliable options. I spent last couple months working on the electrical issues on trucks and learned the in-out of the electrical of the darned truck and don't want to deal with it again. My problems were a bad ignition switch, 2 electrial shorts, and now a bad MSD box.
Thanks in advance.
/td
You need the distributor and ignitor/coil systems. If you have the large cap distributor ('80 up) then you also need the lifter cover with the clearance for the distributor. (Knowing you, you won't want to clearance the cover you have with a ball peen hammer).
(unsolicited opinion content follows):
I am always amazed at the amount of problems that people report with after market ignitions failing. It makes me wonder if Toyota knows something that the aftermarket ignition manufacturers don't.
Thanks Charlie, I'm not familiar with the lifter cover, can you give a little more detail on this?
Has anyone tried to source new '79+ ignition parts from Toyota? Any write-ups somewhere?
Yeah, I wonder myself that why MSD can't make a reliable box just like Toyota.
Thanks.
/td
I bought a used big cap, coil and ignitor and side cover from Mace(Jason) for $150 and sent it all to JimC to check everything and curve it for my "new" 2F with no smog gear. Bought new OEM wires and it works perfectly. I have maybe $300 in it and.....its Toyota:)
Wanna buy an HEI? Mine ran perfectly for the 5-6K miles I ran it on my '74 F, but I wanted the new engine to be all Toyota for some reason:D
Ed
Thanks Ed, I think will go Toyota this time, the truck is running now but the ignition upgrade will be a project this Winter. Can you please give some tips of how you wired the ignition box/distributor/coil? I think I should find a '79+ electrical diagram to get a feel of it.
I have a 2F engine, so anything from '79-'89 will be good?
Thanks.
/td
I already had installed a 30 amp relay switched by the ignition wire for my HEI setup. There is a harness of sorts that connect the coil/ignitor to the ditributor, but wiring the thing is a piece of cake. It needs a switched hot wire, in my case from the relay and the only other wire is for a tach.
I tried to get a pic of the "dented" side cover, relay, wiring to the ignitor/coil and the harness to the diz.
GL:beer:
Ed
couple more...
You can see the red wire and the white wire leaving the ignitor in the first pic and connecting to the diz in the second.
I have not hooked up the vacuum advance, but I have rebuilt a '74 cali-emissions carb with the ported vacuum. Just have not installed it yet.
GL
Ed
Can you not just run the pertronix hooked up to a stock ignition coil? That's all I have in my '73.
As far as MSD boxes....I've never heard good things about them. High performance, but they'll leave you stranded.
Thanks Ed for the pictures, it's a pretty clean setup! Now I got the idea.
As for the Pertronix, that's what I have right now in my non-usa distributor and it works nicely now but I examined it when debugging my ignition and and noticed the red/black wires have worned out inside the dis. and I was prettty careful about not letting them rubbing, and I guess that the Pertronix would be the next one to crap on me.
The MSD/Pertronix Igniter/Frame thrower coil worked beautifully though, it took only one crank to start up and the engine ran strongly, I really like the setup but I will go back to Toyota for reliablilty.
Thanks guys!
Btw, anyone has a good working FJ60 distributor/ignitor/side cover forsale please let me know.
79-87 fj40/55/60 US spec, 88+ no workie
very very easy to wire up.......
Thanks.
/td
