Currently I have a GM column mounted in my 40. The column is mounted quite poorly though, and the steering shaft has no slip joint, nor a rag joint. I will be installing a new column, that has no provisions for an ignition switch, and will be putting an ignition switch back into the dash.
Doors on the 40 are the later model doors with the pull up handle, and what I would like to do is to be able to key the doors and the ignition switch all for the same key.
Does a dash mounted ignition switch exist where the key profile matches the late doors?
Thanks.
Thanks.
