Vehicle: the '92
Problem: I insert the key to start the rig but I can't turn the key. The key WILL NOT turn to ACC. The steering wheel does not have tension on the ignition lock.
Before I break the security bolts on the switch:
Happen to you? Sounds like it's a mechanical problem in the switch.
Hot wiring to get it back home look more complicated than I'd like to mess with right now. [The ele diagram shows touching the starter and a lead to the ignition coil.] ugghhhh.
John?
John?
