Ignition help needed on 72 fj40
My 72 fj40 that I bought about 6 months ago (I've hardly drove it, and it is stock) is very hard to start. If it's cool out at all, forget about it. When I first crank it over, it will fire a couple times but if I let off the key it will die. If I keep the starter turning while it is barely firing, it will eventually start and run on it's own if the conditions are right. If I barely tap the gas or pull the choke out while trying to start it, there's no way it will start. It floods it. Whenever I do get it to run on it's own, at first it sounds like it's only running on a couple cylinders. I mean she's barely running. After 20 seconds or so the idle will slowly speed up and I can then give it a bit of gas and it won't die. Once it gets warmed up, it runs like a top! I figured I'd work on it a bit tonight and start with the basics. The plugs are pretty new, and gapped properly. I thought I'd start by checking the points, timing, idle setting, and then start tinkering with the carb. I suspect it's just too rich. I started with the points and went to set the gap at .018 (manual said .016-.022) and when I put the feeler gauge between the points there were a few small sparks. I didn't worry about it much but put the cap back on and went to start it and it wouldn't start. It's gotten dark and the battery was getting drained so I left it for the night and didn't check the spark. I don't know if I burnt something up (condenser?) or if it was just being fussy. When I start in again in the morning, if it has a weak spark what should I look at?
Also, any suggestions on fixing my original problem? I know it's tough to diagnose over the net, but I tried to give as many details as possible. Thanks for your help!
what plugs are you running i would def. run NGK's please don't run bosch because they are to "hot" for the engine and people have had trouble with them. i would think its a timing problem, if i were you i'd do everything your thinking and then touch the carb last... its so easy to get a carb outta wack that your best luck would be to just leave it be. while you have it running take a can carb cleaner and spray it around all the base's of the intake and everywhere there might be a vacuum, if the RPM's go up on your engine that means you have a leak at that certain spot. go over the hole engine with this and keep checking for unplugged vacuum lines and leaking base plates and what not on the carb ..... best of luck!
72FJ40LandCruiser said:
If I barely tap the gas or pull the choke out while trying to start it, there's no way it will start. It floods it. I suspect it's just too rich. !
Sounds like a carb problem. Normally you need to give it a couple of squirts of gas and pull the choke out to start.
Take a peek at the fuel level in the carb bowl before you start it. It should be the same level as when you parked it. If you can't see any fuel, take the air cleaner off, open the throttle and check for fuel on the bottom of the intake manifold. If it is dumping fuel into the intake manifold, the carb needs a rebuild.
As a band aid, you can try starting it like any other flooded engine. Hold the pedal to the metal while cranking and let up ofter it starts and revs up.
