- Joined
- Apr 24, 2003
- Threads
- 208
- Messages
- 2,210
OK, i was wheeling sunday, truck was running fine, drove off a little ledge, the car stalled, and wouldn't start again (not even the starter spinning)... so pop the bonnet, notice the starter wires are wrapped around the steering colum. plug them all in and the starter works, but getting no spark from the coil... fudge around and take it to a mates workshop.
had a poke around today, had no spark through the points, so i made sure the wire from the fusebox to the +ve on the coil had a nice jucy power flow.. it did. next i ran a new wire from the -ve on the coil to the distributer. still no spark through the points.
new condenser and points, i have spark through the points. replace the coil for good measure, and it starts but runs like it's only firing on 5 cylinders. pull the leads one by one and find cyl 2 and 3 don't appear to be contributing much. replace the leads on there, and back it out into the carpark to play with points gap. no matter how i set the points gap it still runs s***. now timing hasn't been touched at all.
so i swap the old coil back in to make sure it's not coil related. it runs just as poorly with the old coil... idles for a bit then the motor stops again. no spark from the high tension lead off the coil. throw the new coil back on, still no spark from the coil. test 2 other high tension leads, no spark.
so i still don't have a running truck. it gets spark through the points still, so i'm stuffed as to whats causing it. i've tried numerous points gaps and it won't spark out the coil anymore
yes i've checked fuses.
any other ideas?
any other ideas?
