Ignition coil installation
Northern VA
1972 FJ 40-
About to install new Flamethrower coil from pertronics on the F engine, and noticed that at least half of the owners pics on this site have the coil tower pointed UP, while mine and most of the others have the tower pointed down.
For you UP guys, what's the reason? Does the tower wire to the dizzy stay in better under rock crawling; do you like the look better; or what?
Thanks, Lynn Blasch
The orientation does't matter, since it is hermetically sealed. Toyota mounted them tower up and sideways.
I'm not a big fan of super duper after market coils because they don't add anything useful and they can be less reliable. If they do end up generating more power and a higher voltage, points can burn our faster and you can have problems with the insulation breaking down and spark migration in the distributor. All it needs to do is make a spark across the plug and anything more is wasted. A good analogy is horses: If you have a race horse, you need a race saddle to get the most out of it, but putting a $100 saddle on a $10 horse isn't going to make it run any better.
Thanks for the install info.
On 2/15 I posted a thread titled "FJ 40 runs, quits, then runs again" which noted that we could get the car to run for a bit, then we would have no spark for about 30 minutes, then it would run again.
I decided to switch from points to PerTronix ignitor, and also ordered the higher voltage coil at the same time. I think the two will work well together, if I can get anybody to send me the ignitor. Kits for this car are out of stock everywhere.
I just thought that the tower-wire-up installation looked strange, especially if you have brightly colored plug wires.
You can point it downward if you want. Gravity and vibration might disconnect your kinglead now and then but that's part of the fun, eh?
