I am having some ongoing issues related to the igniter in my '94. I was originally trying to figure out why my Tach stopped working...after some trial and error, I replaced the igniter, and it started working again. In the process of trying out a new igniter, I purchased 2 from RockAuto...one resulted in crank/no start. The second igniter would crank, engine would fire and run for about 2 seconds and then die. I purchased a third igniter from AutoZone, and that one worked (engine ran, and tach worked again). However, thinking I would be better off using OEM parts, I returned the AutoZone part and ordered an OEM replacement igniter. When I installed the OEM igniter, I got the crank/no start again. This is very bizzare...does anyone have any ideas as to what may be causing this issue? I tested the resistance on the coil and all appears to be fine. Only thing I can think of would be a weak signal from the ECU to the igniter??
