Igniter compatibility
So. Cal
Would an igniter from an SC400 work on a FZJ80 of the same year?
The part numbers are the same. I'm just wondering if they do anything differently for the different models.
I recall seeing that the same igniter was used across multiple platforms. It makes sense.
Quoting from a post I made in 2010...
I bought one off Ebay ($25 delivered) and it works fine (tested on my 80). Do note that if you plan to test another ignitor in your 80 you MUST screw it down to the bracket. The ignitor gets its ground connection through the bracket and will NOT work if you just plug it into the harness and let it 'dangle'.
The one I bought was listed as for "Toyota Tercel 3E-E 3EE COIL IGNITER 91-94 92 93 94 1994" which has the exact same part number as the one on my '97 80 series.
A friend had his 80 die on the road, it had no spark. Turned out that one (or maybe both) of the pickup coils in the distributor had failed (corrosion etc) and so the ECU would not fire power to the coil. So, plugs or output of coil not having spark can be more than just the ignitor failing.
cheers,
george.
