igintion switch bad ?
Dusty 66
Ball & Claw Club
Nevada
The OEM ignition switch and wireing on my 66Fj40 is all stock it was gone through tested repaired and re wraped its all good and put away 10 years ago I wired up the new 2f with an new eletronic ignition primed it fired up for a min it ran good just did this with body off checking the ignition switch becouse the cut off switch did not shut off. the switch is hot in the off position ING ACC and BATT is my stock ignition switch bad ? :confused:
Did you use the alternator off the newer 2f, it may have the need for a start relay to excite the alternator and to stop the exciter after the ignition switch shuts off, the relay drops the excite wire when charge begins, without the relay it will keep charging and keep the motor running, just a thought, Larry
Yes new alternator on the 2F its a late 78 2F the old 66 1F had one too. I just used a 2F pig tail and sodered it to old wire harness. JC
There is a wiring diagram for a 78 in the technical links section it shows the color code for the output wires there is an exciter lead a field lead and the battery lead, I can't tell how the regulator for the early alternator works but the regulator in your older cruiser should have the leads labeled F for field and e for exciter just make sure that the leads are soldered correctly to their counterparts, the newer regulator may be needed to make it work properly. I'll look around for an older wiring diagram tomorrow if you find you are connected correctly, my 70 cruiser had some differences but I can't remember what they were. Larry
Dusty 66 said:
The OEM on my 66Fj40 is all stock it was gone through tested repaired and re wraped its all good and put away 10 years ago I wired up the new 2f with an new eletronic ignition primed it fired up for a min it ran good just did this with body off checking the ignition switch becouse the cut off switch did not shut off. the switch is hot in the off position ING ACC and BATT is my stock ignition switch bad ? :confused:
OEM is original equipment manufacturer, so I don't understand what you mean.
It sounds like the switch may be bad, but you won't be sure unless you disconnect the wires and check it with an ohm meter because there are other reasons that all of the poles might be hot with the switch off.
:whoops: I ment wireing was OEM and the new Toyota ignition $$ switch I tested with an ohm meter but wireing was conected. I will pull the wireing and test again when I git back , I am leaving for Death Valley be gone a week going to go play :cool: . I will post more when I return .
THANK's JC
My Iginition switch is OK I checked it disconected from wireing loom:)
But looked at my wireing whare I conected the alternator the B terminal is conected to the large 8 gage white w/Lt blue stripe. The terminal F white w/green stripe 16 gage goes to F side of the Regulator. The terminal E white w/black stripe 16 gage to Regulator /ground. The terminal N white wire w/Lt blue striped wire 16 gage is conected to a... :whoops:...nothing :o I am not sure ware to conect this wire to back to regulator? do I need to upgrade my regulator:confused:
