Mini guys put IFS hubs on their minis, does that mean they could be used on an 80 for extra width?
I want locking hubs as a just in case kind of thing. IFS hubs are a dime a dozen and I can get them free easily. Wouldn't I then need to get the 30-spline conversion from Bobby Long? And wouldn't this also give 1.5" extra width each side?
Are you talking about just swapping your drive flanges for locking hubs? I did this on my 93 and yes, my 'axle' is wider (lockout dial to lockout dial) but my track width did not change.
The Spindle Assemblies are different on the 80's..
But the Lockout Hubs from an IFS will work if you order bobbys Hub Gears Longfield Super Axles Designed for the IFS hubs.. That Plus longfields is the ticket for a strong setup and less wear and tear on your Birfs..
you 80 guys can lock the CDL and unlock the hubs so you can cruise around town in 2wd.
If I am understanding this correctly, there would still be power transmitted through the front drive shaft and through the birf's, but the front wheels are disengaged and therefore do not drive. I'm interested why more people don't do this instead of the center coupler mod. That is of course if there is nothing wrong with the rest of the drive gear spinning freely in the front axle.
So IFS hubs with Bobby Longs hub gear WILL fit and work as a lockable hub on my 80 series front axle? Width gain or not....
bam671, if you have an early axle, which you do, i assume it would still work.
i bolted IFS locking hubs to my 80 axle and it still allowed to much play, but i have a 93+ 80.
I also had a ton of manual hubs laying around so i just took the hub gears from SA hubs and rebuilt the IFS hubs with the SA gears.
saves you 60 bucks if you have some SA hubs and a little time.
for the later 80s, a new groove on the existing birf seems to be the easiest thing to do.
