Idler Pulley problem
Durango, CO
So when I bought my 80, one of the idler pulleys sounded like a freaking supercharger on crack. Very loud high pitched bad bearing noise.
So I bought a new OEM one. Problem is, the new one sounds just as bad. I want to know if you have experience with this, did I do something wrong, do you know why it making so much noise, and what can I do about it. At the moment I'm driving without it, but I figure it's there for a reason....
In the picture it's the one under the alternator right below where the adjusting bolt arrow is pointing.
I had a similar experience. I proactively replaced both idler pulleys at 200k miles, and the new a/c pulley made all sorts of noise, while the old one was quiet. Just replaced the a/c idler pulley again. Seems to have solved the problem.
What are the condition of the belts? New or old? Factory or aftermarket?
How about the tension of the belts, that could play a factor as well.
I found that if you have belts with groves in them thy make a loud noise I replaced mine with the factory belts and problem solved:bounce:
The belts are not OEM, they are not smooth either.
I know it's the pulley I took out, because It stopped when I took it out.....
Betcha a dollar it's still the belts and that a matched pair of new Toyota belts will fix it ;)
I'll try it.
But Here's why I'm hesitant to think it's the belts: so this guy (the original owner of the 80) takes his Cruiser in to his mechanic, and gets new belts. He gets it back, and it sounds like a rice burner whinning it's head off and looking for a place to pull over and die, and the guy ignores it by cranking the radio? or asks the mechanic and the mechanic feeds him one hellofa reason why and he bought it?
I can't imagine driving around for a long time with that much noise coming from the engine bay.....
My ac idler was making a horrible sound so maybe check yours? I cut the belt and solved the problem for now..
D
It's the belts man. The grooved belts have a whine when they rub against the idler. Remove the idler, tighten the belts and try. I bet they don't whine anymore. This is of course a temp soln.... you should get the non grooved belts and put the idler back on.
x 10 on the belts. I had the same thing happen. I was SURE it was the power steering pump. Drained, refilled, bled.....no go. Still whined. Then, I took off the idler pulley and the noise stopped. Needed a new idler, right? Nope. Bought a new idler from Toyota. Same exact whine. Then, changed out grooved or "cogged" aftermarket belts with new, smooth Toyota belts......quiet as a mouse ever since.
It doesn't seem possible that just the belts could produce that much / that kind of noise...........but they do!
I'll try it.
You would be surprised what people will do.
x100 on the belts! And OEM belts are only a little over $20 for the set!
Problem will be solved... (been there, done that)
Agreed. OEM belts are the way to go. Do that first and then see where you are, and then suspect the pulley.
