On cold startup after the initial higher rpm warmup and kickdown-- i get a low-400rpm idle for a few minutes(or a few blocks of driving)and then it stabilizes at 650rpms once warm and no issues afterward--only on cold start.
-I recently installed Metaltech Sliders-(removed stock cat prot.)
-New O2 sensors around the same time
-checked for vaccuum leaks
-recently adjusted throttle cable which was loose and somewhat sticky.
Is it possible the cats arent warming up fast enough due to the stock protector removal and giving the computer false 02 signal causing the low initial idle? Anyone else with Metaltech slider/stock cat prot removal running into this on colder mornings? Or should i be looking elsewhere...
