idle problems
CANADA
hi, my 80 has been having some eratic idle issues, when i start the motor, it idles extremley approx 2200rpm, until i shift and go. then at stop lights etc idle jumps to 1800 and lurches forward,, then dies to below 500 somtimes. itsd a bit worrysome cause it actually luches forward on a weak brake foot, i've almost hit the car infront of me. wondering if anyone has had this experience, dash lights are clean...no light, just had fuel filter and spark plugs and distrb..cap replaced, use premium fuel, regular oil changes and air filter,,, any suggestion to what it is
thanks
A few guesses...The high startup idle is often related to a dirty throttle body which could also cause the low and high warm idle problems. Other common prob is a sticky throttle cable. The irratic warm idle can also be related to the large rubber intake hose being cracked, usually on the underside between the ribs. All three are easy fixes.
My first thought was a defective o2 sensor since one of the things they do is control idle functions, BUT you should have a check engine light if that were the case?????
Sounds like something is messing with the throttle plate motion. As posted above the first culprits are a dirty throttle body and worn throttle cable. I'd order a new cable and do both at the same time. Just be sure to get throttle body specific cleaner. The Carb cleaners can damage some of the components of a Throttle body.
Glad to see you on mud Jim.
I've picked up a bunch of 4runner stuff from you guys in the past. PLEASE make some more 80 products. Like your headers for an 93-97 80 series. Nice to hear from you.
