I'm a little confused with this one...
I have a intermittent idle problem. Sometimes, with the engine at normal temp.( 185 deg), my idle drops at approx 500 rpm . If the engines stalls, I start it over and the problem is gone with steady idle at approx 850 rpm...
- The idle solenoid is making the ''clic'' every time I put the switch on ,so I think it's o.k.
-The fuel level on the carb's window stays in the middle when the idle drops.
-I changed the 2 fuel filters just in case...
-Can I have some dirt in the carb's fuel bowl?
I hope I didn't forget any details.... BTW it's a 1977 2F engine with 1971 carb and dizzy with pertronix ignition.
Again, thanks for you help! It's REALLY appreciated
