Idle Mixture -
Austin, TX
I've been DDing my 40 for the last week or so because my 80 is down, and noticed a little carb adjustment is in order. I'm getting a puff of black smoke at startup and a little burn-off in the exhaust at idle. I assume this means it's running rich and need to adjust my idle mixture. I've read to adjust in 1/4 turn intervals and test ... this means 1/4 turn in correct? Just wanted to make sure -
Thanks!
Tucker
Not necessarily the carb. If your valve stem seals are on their way out then a little oil gets past the seals when you shut it down. This can cause the puff on start up and idle.
As for the mixture screw. Get your lowest idle, and turn the screw in until it starts to sputter. Then back the screw out until it idles steady, and about 1/2 turn out after that. Return idle to 650 rpm
