Experts I need your help,
Symptoms: Rough idle when choke is all the way off, drop off of power and stutter when accelerating
Corrections so far: New spark plugs, Okie carb "rebuild", carb cleaner sprayed through, new vacuum check valve and hoses
I need your help identifying this leak. I replaced the vacuum check valve and it didn't solve the problem, but after spraying carb cleaner on the master cylinder mount the leak hisses louder (see video). No drop in RPM when I sprayed all around the engine when running. If there just a gasket that can be replaced? Anything else I'm missing? Thanks in advance for the help.
Spray Test
Exhaust Sound
Engine Running Overview
Spray Test
Exhaust Sound
