Identify this distributor
Tulsa, Oklahoma
Sorry this picture sucks. I recently found out I am a tard and have a vac retard distributor hooked up to a vac hose on my F motor. I am told that Vac advance is the way to go. Is this dissy that came with my used motor a vac advance? Also would a vac retard still run smooth and nice if it was hooked up to a vac line. I have had no problems , my truck runs great ..just a tiny bit of sputer when you get on it and runs really rough when it is cool until it get warmed up. That tab on there say "densol japan and 2F" if that helps.
I had the same issue....vac advance dizzy with no fitting. I took the fitting off and went to the local NAPA autoparts store. They didn't have the exact size, but used a copper fitting with that was close enough with some copper tubing. Just wrapped it in teflon tape and screwed it on in. I know that the threads are now messed up on the fitting, but for $2, can't beat it and I know that it isn't leaking.
why not go to electronic dissy much better than the old point style engine runs much better good luck
The stock fittings are still available.:)
