I can't remember if my sm420 is a 1953 or a 1954, that was a transition year for the input seal, and mine is dumping gear oil all over my clutch. If it had the neoprene input seal it is no longer existent. I can't put an image to Novaks description.
# 1947-1953: No ribs on the case, grooved input shaft instead of neoprene seal. Synchro rings all differ from each other. 1st-2nd synchro ring is bronze. Six digit casting number on the case, usually like "591xxx".
# 1954-1963: Same as previous but uses a neoprene input oil seal.
Pictures of front
you can see there is a taper in the shaft right as in exits the input bearing. I'm not sure if that is "grooved input shaft"
I took this thing apart last night cause I thought just the adapter was leaking and my rear main, its turning out to be all sorts of s*** jacked.
I need to get this thing back together quick like so I can go to work on monday.
I have heard that some people have their front retainer machined so a sm465 input seal will fit, is that correct?
Pictures of front
