Ideling Issues
Portland, OR
Last weekend my Land Cruiser started to idle very rough. Well at first it wouldn't even idle, till a carb guru looked at my Aisin carb and we cleaned out the float and got my rig to idle again. I dropped it off to the mechanics to get some work on it and they took a look at the carb.
When I drove my cruiser home 30 miles back, as I pulled into the parking lot, my cruiser started ideling slightly rough again. On the vacuum gauge it would go from 21 psi to 16 psi. Could this be because of a cracked manifold? Or do I need to get my carb rebuilt? I'm going to go replace the fuel filter today since there was dirt in the float bowl and see if that helps any. Any other suggestsions would be appreciated. Thanks.
Travis
I was a little unclear about the float thing, it was another guy that filddled with the float problem and we got my rig ideling again so I could drive it home. I then dropped it off the mechanics to work on it. The mechanic definately fixed the throttle response because it acceerates way faster now. I'm going to change the fuel filter soon and see if that helps, looks like the fuel filter hasn't been replace in awhile.
Travis
