Sent the Block and the head to the Machine Shop fairly stripped, though the timing cover was never taken off when I gave it to them. I got it back in more pieces then when I had given it to them, I figured mostly everything out except for this Bolt (and nylon washer).
It doesn't fit anywhere on the head, but it is the same size as the bellhousing bolts, motor mounts, and knock sensors... Obviously it isn't any of these. The only other hole on the block or the head this fits in is right here under the timing cover. Is this where it goes? What is its purpose?
Thanks.
Thanks.
