ICS troubleshooting...
2/79 FJ40 (see previous post by me) https://forum.ih8mud.com/showthread.php?t=39566
I'm not getting any spark from the high tension cord off the coil...here's what I've done. (Remember this is an engine test run, no wire harnesses in place!)
Coil primary - tests about 2.3 ohms (slightly high according to book spec)
Coil secondary - tests about 13 kohms (within book spec)
With 12 volts applied to the white wire of the ICS duplex connector (which I believe powers the ignition circuit) I get the book spec 12 volts between the coil positive and ignitor body. If I apply power to the pink wire of the ICS duplex fitting there is no voltage present.
Not really knowing what to do next, I tried a test of the power transistor in the ignitor. I took the info from the FJ60 2f engine manual, since the ICS looks more like what I have versus what is shown in the earlier manual I have for the FJ40.
So, using a 1.5V source to the wires and connector coming fro the ICS which plug into the distributor (which I believe in this case it to energize the transistor), and energizing the ignition circuit with 12V via the white wire of the ICS duplex connector I check for a 5V voltage drop across the coil and ignitor body. There was no drop of voltage from the 12V which was applied to the ignition circuit.
Finally the question...If this is a valid check, does the lack of voltage drop somehow screwup any output via the high tension cord or should I still be able to jump a spark to ground from the distributor end of the cord.
Any recommendation for the next step in troubleshooting?
Is it time to buy a new ignitor and coil system?
All ideas eagerly awaited....
Thanks
Dave
