- Joined
- Mar 16, 2003
- Threads
- 201
- Messages
- 615
Ignitor and Coil question...followup question
I think I understand how things are suppose to be hooked up but wanted to run this by those with more experience...
Frame off renovation on a 2/79 FJ40. I'm getting ready to test run my engine before putting on the body. Everything in place with exception of any wire harnesses. Starter turns over when I apply power to the starter terminal. Now... I know I need to get power over to the fuel cut solenoid, and power to the coil to make things happen. I also see by the electrical diagram that the start circuit applies 12 volt to the coil, and the ignition circuit passes voltage to the coil after passing thru a resistor.
My questions revolve around where to "tap" for 12 volts on start, and then for the lower voltage after start, and how do I get these voltages to the coil. I'm concerned about burning out the coil or ruining the ignitor.
(1) Can anyone give me some insight as to what circuits the single and double blade connectors on the coil require and route to? (see picture) I know where the third connector with longer wire goes (my dizzy.)
(2) Any problem with directly applying 12volts to the fuel cut solenoid without going thru the emission computer I/O's.
I've almost got my head wrapped around this thing, but not quite. Any and all comments or insight would be appreciated.
Cheers, and Keep on Cruising!
Dave
Dave
